Ir para o conteúdo principal
A Samsung NX Mini é uma câmera digital mirrorless lançada em março de 2014.
Zoom lens won't unlock
I have never drop this camera or taken off the lens after first putting it on. It's been about 9 months since I had this camera. The zoom lens won't unlock after rotating it like I normally would. This has been going on for 2 months. What can I do to fix it so the lens will unlock and I can use the camera again?
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
5 respostas
Pergunta mais útil
I had this problem too. I took out the 3 outer screws on the back of the lens, one seemed loose, peeked in and decided there was no way I was going to fix this thing. Screwed it back on and the camera worked again. I suspect the screws were loose. Give that a try and see if it works.
I know I was about to throw my NX-mini out when I took the chance of unscrewing it. I wouldn't try to remove the back. Just try tightening the outer screws.
Update (10/27/2017)
Update: It stopped working again.
I had a technician at work take a look at it and he found that a ribbon cable in the lens sheared. He removed the cable and it works, kind of, in manual mode. I will be sending the lens to International Camera in Chicago to have it repaired.
Esta resposta foi útil?
Pontuação 4
5 comentários:
Thanks Man. You really helped me.
por
omg thank you so much this helped
por
Its a really answer, thanks a lot brother
por
Thank you! Great!
por
My case is "kinda". I have to dismantle the lens, tighten the inner ("second layer") screws, re-set the main cable (which seemed to be totally fine), and it works again. But tighten the outer three screws did not work.
por
It works for me too. Just tighten the 3 outer screws, then on off once.
Pontuação 0
You legend! Thank you!!! It worked. Might I add that I had to remove the three outer screws and put them back in before I was able to successfully fix it. So thank you for sharing your answer.
Pontuação 0
Well you should go to near camera repair or hardware repair shop and give to some one who have the proper knowledge of how to fix this type camera.
Pontuação 0
If you break the flex print it also unlocks again. Mine was likely already damaged and broke completely off in the last steps of re-assemble. Don't see any drawbacks but haven't used the camera much in the last 4 years due to this constant issue ;)
Pontuação 0
Adicionar a sua resposta
katiexyooj será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 35
Ao todo: 6,048
