Ir para o conteúdo principal
Android's 4.4 OS with a 1600 x 2560 pixel resolution.
Is my screen dying?
Hi, my screen is showing some weird artefacts on screen, at first there is not much but its getting worse after few muniutes of use. If i lock and unlock the device i show white light bleed on left side of the screen (first picture) then if i lock again, wait for a while it disappears, but some artefacts and color pixel start to show on left side (second pic). After a while some strong white lines apear, always in the some spot, but if i put down the device for few minutes it desappers. Reattaching battery didn't help, i guess thats not the case. Could this be a faulty LCD connector? Or the screen is dying.. ? Definitly not a software bug, i just upgraded to 6.0 and even in bootloader mode while upgrading there were those two lines (last pic)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
UPDATE: I can confirm that the screen (LCD) was damaged, got it replaced. Nothing could be done to fix it.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
El Donkey será eternamente grato(a).
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 11
Últimos 30 dias: 13
Ao todo: 302
