Ir para o conteúdo principal
The Kenmore 90 Series is a washing machine manufactured by Kenmore.
a sheet, probably wrapped around
My washer is a stacked unit w dryER on top. The problem I have is it doesn't have the agitator.....it's a sheet, probably wrapped around the new style washer's middle thingy. Please help! Thanks!
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Jennifer Rose, what make and model is your washer?
por
Adicionar um comentário
1 resposta
Solução escolhida
Jennifer, You may have to remove the impeller/wash plate to get the sheet untangled from beneath it.
Below I will post a video, may not be your exact model but will show how a impeller is removed. In the future it is best to include all the info. you can make, model #,etc. as oldturkey suggest in order for ifixit to give best solution. Check the attached vid. link, Good luck.
https://www.youtube.com/watch?v=zRJQ7q70...
Esta resposta foi útil?
Pontuação 2
1 comentário:
How to remove a stuck Kenmore 500 Series Impeller?
por
Adicionar a sua resposta
Jennifer Rose será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Ao todo: 1,624
