Ir para o conteúdo principal
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 Perguntas Visualizar todos
What are the connector names to the display?
My friend has a non-working iMac. My goal is to reuse the display as a 27" screen to connect to a tower PC.
I currently have access to the non-functioning iMac with its hard drive removed. I opened following tutorials here. I then ordered and got delivered a controller board. When I tried to connect the controller board to the display, I realized that the connectors were male on both sides. I figured I needed a female-female adaptor. My problem is that I have no idea what name those connectors have, and thus can't look for any kind of adaptor that would fit...
I'll add pictures of the controller and the endings of it.
Edit : Here they are : http://imgur.com/a/7GhO7
Esta é uma boa pergunta?
Pontuação 0
4 comentários
Who's controller board did you get (make & model)? If you have a URL to it please supply it as well.
por
This is the one I bought :
http://www.ebay.com/itm/HDMI-DVI-VGA-Aud...?
They title it : "HDMI+DVI+VGA+Audio LCD Screen Controller Board Monitor Kit for LM270WQ1 SD E3 "
por
Any chance you can post an image of the label on the back of the LCD panel?
por
Here it is oldturkey03 : http://imgur.com/TFfUdE9
(more taken during the opening here : http://imgur.com/a/EaeNh )
por
Adicionar um comentário
1 resposta
Pergunta mais útil
It may take some effort but personally I would make use of the free repair program. It's about at its end but someone else on the site, just today got Apple to repair it:
https://support.apple.com/en-us/HT203787
iMac (27-inch): AMD Radeon 6970M Video Card Replacement Program
Apple has determined that some AMD Radeon HD 6970M video cards used in 27-inch iMac computers with 3.1GHz quad-core Intel Core i5 or 3.4GHz quad-core Intel Core i7 processors may fail, causing the computer’s display to appear distorted, white or blue with vertical lines, or to turn black. iMac computers with affected video cards were sold between May 2011 and October 2012.
Esta resposta foi útil?
Pontuação 1
2 comentários:
The problem within the broken mac is _not_ within the video card (most probably it would be the logic board). I am not trying at all to repair the iMac, but mostly trying to recuperate the display block and turn it into a screen.
por
Sorry, that's way outside my area of expertise. I just fix 'um. @oldturkey03 knows a lot on this than I do.
por
Adicionar a sua resposta
moza será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 398
