Ir para o conteúdo principal
O eMac foi um computador Mac com processador G4 tudo-em-um, projetado para o mercado educacional e lançado em abril de 2002. Foi o último Mac a usar uma tela CRT e foi vendido a um preço acessível para escolas e outras instituições.
Why doesn't my eMac start up?
Apple eMac G4 start up problems
Hi!
I recently received an eMac knowing it was faulty and wish to try and fix the problem!
I press the 'power on' button, it chimes, then accesses a white page with the apple logo and spinning sign and finally gets to the stage of 'starting Mac OS X...' but won't go past this page even after leaving it for nearly an hour.
Any solutions are welcome!
Thanks
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Please identify your machine for us here are the eMacs:
http://www.everymac.com/ultimate-mac-loo...
por
Adicionar um comentário
1 resposta
Solução escolhida
Without knowing your exact machine I can not tell you the range of Mac operating systems it will take. That given. all will run 10.4, Best if you have the original system installation disk. Insert the disk, restart and shove the disk back in and hold down the "C" key. Go to the second page and the pull down menu will appear. Go to disk Utilities and run Disk Doctor and see if you can repair the hard drive.
Either your system is corrupt, has the wrong system or hard drive has gone bad.
Disk Utilities failing, I would then reformat the hard drive (using the "write zeros option, to map out any bad blocks), Then reinstall a new system.
If you do not have the installation disk, you will need to give us your exact machine. That information should be printed on the back or bottom of the machine. Then we can direct you to the correct system to install and where to get it.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
mgeri será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 19
Ao todo: 801
