Ir para o conteúdo principal
The Kenmore Direct Drive is a washing machine by Kenmore.
58 Perguntas Visualizar todos
kenmore top load washer model #110.298328011 will not start
I selected the wash cycle and my washer just started to fill and then it shut off and there is power going to the washer but it will not turn on and I do not know what the problem is with it?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
ken. possible the lid switch could be faulty, I will search for some links for you to check out soon.
por
Adicionar um comentário
1 resposta
Solução escolhida
ken. possible the lid switch could be faulty, faulty timer,etc, also check all wires and connectors at timer switch/main control and motor. If you are not comfortable disassembling machine and testing components have a good appliance technician have a look, diagnose and estimate repair. Check the attached links,instruction and guides, Good luck
https://www.youtube.com/watch?v=TBeymPFy...
https://www.youtube.com/watch?v=q82wD659...
https://www.youtube.com/watch?v=7STcI9xw...
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thank You So Much for the help....:)
por
Adicionar a sua resposta
ken johnson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 146
