Ir para o conteúdo principal
MacBook Pro models with a 15" display
8251 Perguntas Visualizar todos
MacBook Pro, starts then gets a black screen but still on?
Hi!
I have an MacBook Pro, 15 inch.
When i start it, the starting sound appears with a white screen for 2 seconds.
After 2 seconds of white screen, the screen goes black and dont turn on after.
The Computer is still on though, harddrive spinning and also the fan.
I've tried to reset SMC and NVRAM/PRAM, but doesnt help.
I think it might be that the computer goes into sleep straight away, or thinks it should use a external monitor?
Any other ideas?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
We really need to know your exact machine. there are recalls, different issues on different machines.
This could be hard drive, hard drive cable, GPU or something else or a combination of issues. Please go here and enter your serial number and tell us what you have, the number is generally on the back in fine print on 2009 machines or in the battery compartment prior to that:
http://www.everymac.com/ultimate-mac-loo...
MacBook Pros have been in production for 10 years and there's lots of them:
http://www.everymac.com/systems/apple/ma...
Esta resposta foi útil?
Pontuação 1
1 comentário:
Will do that when i get home!
I think its a 2010 model, but i'll send exact model in a couple of hours
por
There is a recall for your computer. Call apple they will help you! Otherwise it could be anything, hard drive or CPU! Tell us what computer you have and then we can help you. On most models you can find out what computer it is be going to the apple logo on the top left hand corner of your computer, then press about this mac. Get back to us when your done!
Pontuação 0
3 comentários:
Yes, i'll send you the serial number of it later.
Can't get into the computer because the screen is black,
por
ok you can also get it on the back! good luck
por
What recall on a 2010?
por
Adicionar a sua resposta
viffviff será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 111
