Ir para o conteúdo principal
1.4GHz or 1.6GHz Processor / 64GB or 128GB SSD
162 Perguntas Visualizar todos
Any idea on the exact processor used?
well just as the question asks, any idea on the respective chips used in the mba?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Pergunta mais útil
Intel® Core™2 Duo Processor SU9400
(3M Cache, 1.40 GHz, 800 MHz FSB)
Intel® Core™2 Duo processor SU9600
(3M Cache, 1.60 GHz, 800 MHz, FSB)
Intel® Core™2 Duo Processor SL9400
(6M Cache, 1.86 GHz, 1066 MHz FSB)
Esta resposta foi útil?
Pontuação 5
1 comentário:
good research +
por
Also the SL9600 2.13GHz.
Just a note: these are the fastest chips available in this class. The 11" uses 10W chips. There are no Core-i processors in the 10W family. The 13" uses 17W chips. The only Core-i offerings in 18W are much slower chips. Those griping about using these chips are buying into the Intel marketing hype rather than looking at specs. At some point, Intel will have 18W Core-i5 chips that run at 1.8GHz before any Turbo mode, and then they will be worth looking at. Until then, the Core2Duo will have to do.
Pontuação 2
Adicionar a sua resposta
Jon será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 1,717
