Ir para o conteúdo principal
Um GPS com tela sensível ao toque lançado em fevereiro de 2012 pela Garmin, com pontos de interesse personalizados e visualização de cruzamentos. O tamanho da tela é de 4,3 polegadas na diagonal com resolução de 480x272.
Why Won't My Touchscreen Work?
My device will turn on but when I press the screen to make any commands I can not prompt any response. Please help.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
There are three possible problems that are associated with an unresponsive touchscreen. They are listed from easiest to hardest to complete.
Dirty Screen:
  • If your device has a screen protector, remove it
  • Spray a bit of water or formulated spray onto a microfiber cloth.
  • Wipe thoroughly.
  • Using another dry microfiber cloth, immediately dry the surface.
  • Replace the screen protector with a new one if desired.
Resetting the Device Without Using the Screen:
  • With the GPS unit off, press the bottom right hand corner of the screen. Turn the unit on while maintaining pressure in the bottom right corner. When you see a prompt asking, "Do you really want to erase all user data?", you can release your finger and select yes.
  • If the bottom right of the screen is unresponsive then please refer to the broken screen guide.
Broken Screen:
  • If your device screen is still unresponsive after following the following guides above please refer to this guide for replacing a broken screen
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Nathaniel Williams será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 782
