Ir para o conteúdo principal
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
T7200 Intel processor on iMac 1207
Can I use a 2.0ghz T7200 Intel processor on this logicboard?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Can you tell us why you want to downgrade? I've done several upgrades but not the other way around.
por
Adicionar um comentário
1 resposta
Solução escolhida
Yes, the Intel Core2 Duo Processor T7200 (4M Cache, 2.00 GHz, 667 MHz FSB) is compatible.
I'm not sure its worth upgrading here as your system only has a 32bit EFI so it can't run any OS newer than Lion (10.7.5)
Also finding these older CPU's that are the try type can be tricky! Heres the IFIXIT guide you'll need to follow: iMac Intel 20" EMC 2105 and 2118 Logic Board Replacement it will only get you to taking the logic board out.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
jeanlemure será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 13
Ao todo: 199
