Ir para o conteúdo principal
Parte da linha de smartphones Windows Lumia da Nokia. Anunciado em julho de 2013.
Nokia lumia 625 power button not working. How to repair?
Today in the morning I just dropped my phone while opening the back cover of my Nokia lumia 625. When I tried to start it did start, but the screen got hanged. I opened my back cover and saw that some parts of the power button were missing. I want some help how to fix it along with a video.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
You can try to disassemble the device and to reconnect the Volume/Power buttons and the LCD flex cables.
Use this manual, step 3, pic. 3
Under the battery there are two flex cables. The yellow one is for the volume/power buttons the the small board in the bottom (mic, antennas, USB connector, etc.).
The black one is for the LCD. Both of them are connected to the main board, under the main camera. Try do disconnect and reconnect them. You don't need to remove the battery, only disconnect it.
Substituição da bateria do Nokia Lumia 625
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Saumya Brata Dutt será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 20
Ao todo: 5,578
