Ir para o conteúdo principal
The Audi A6 is an executive car made by the German automaker Audi AG, now in its fourth generation. All generations of the A6 have offered either front-wheel drive or Torsen-based four-wheel drive – marketed by Audi as their quattro system.
30 Perguntas Visualizar todos
My car is haunted
2004 Audi A6 Quattro: Turn signals click but sometimes stop and I have to manually click. Rt. signal interior light does not light. Also the sun roof opens all by itself and when it feels like it and closes by itself. Any ideas where to start my search? HELP.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
Hi Andy,
I had a Jetta that did many of these things forever. Turned out to be issues with the faulty electrical wiring. Here's a helpful article about electrical problems in vehicles:
https://gobdp.com/blog/diagnosing-electr...
Alternatively if it is a ghost you can try these steps:
http://www.wikihow.com/Get-a-Ghost-out-o...
Esta resposta foi útil?
Pontuação 4
Andy, check and test all signal light bulbs(even if they look OK), check wires/grounds and plugs for damage and corrosion. IF all are OK, change signal flasher, if still not working could be the multi function/light switch faulty.
As far as sunroof problem opening and closing on it's own, forums I have read say it is the sunroofs potentiometer faulty. Check the attached links,instruction and guides, Good luck.
http://www.audiworld.com/forums/a4-b5-pl...
http://www.audizine.com/forum/showthread...
Pontuação 2
All else failing this link will tell you who to call
in the UK it's
0800 2229 911
USA
1-212-897-1964
https://www.youtube.com/watch?v=Fe93CLbH...
Pontuação 2
Adicionar a sua resposta
Andy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 10
Duração total: 282
