Ir para o conteúdo principal
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Perguntas Visualizar todos
Can't get top right corner screw back in.
I took apart my iphone 4 and, as expected, had trouble removing the top right screw (near the audio jack). Now that I am trying to reassemble, I CAN NOT get the screw back in. I have been working on it for an hour.
I am using the tool kit from ifixit and the screw driver hand is too thick to be able to get a direct line on the screw. I need some advice on how to proceed.
1. Is their a screw driver with a longer thinner shaft that might work?
2. What happens if I leave the screw out altogether? (I did try that but the reassembled phone is unresponsive.
Any other ideas?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi !
As long as this screw is a contact screw, there's no surprise about your phone not responding once reassembled.
I suggest that you use different screwdrivers, not being able to give you an accurate reference as long as I no longer own an iPhone 4. If you still can't manage to screw it or that the head is a bit damaged, some tools sold f.e. at iFixit may help you. I personally use this one for damaged screws.
Imagem de Screw Extracting Pliers
Produto
$19.99
Esta resposta foi útil?
Pontuação 1
2 comentários:
The screw head is still undamaged. I just can't get the screw driver and driver head alligned.
por
Have you tried with a flat one ?
por
Adicionar a sua resposta
A S Koski será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 48
