Ir para o conteúdo principal
Repair guides and support for coffee makers by Keurig including the K-Cup systems.
495 Perguntas Visualizar todos
model k48 keurig lights flashing
My model k48 has been unused for several months, but still in the house and upright. When I plugged it in, all the lights started to flash and would not stop. Customer service was of no help and offered me a discount on a new one. Anyone have a solution other than buying a new one? Thanks.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
3 respostas
Solução escolhida
Try resetting the Keurig by pressing the auto-off and both the cup size buttons simultaneously. All the lights should go dark and then return to normal. Thanks to Amazon user PJP for the suggestion!
Esta resposta foi útil?
Pontuação 5
7 comentários:
Did the trick...Thanks
por
I did what you said and it fix my keurig machine thank you very much for your solution.
por
Thanks for the tip. Enjoying a fresh brew right now
por
Thank you!!!! It worked!!!
por
What worked, I don't see a solution?
por
Exibir mais 2 comentários
Thank you, it worked!
Pontuação 0
Did not work. Still flashing Ugh
Pontuação 0
1 comentário:
Tried every solution....unplugging to reset,cleaning needle,making sure water tank is sitting ok and pressing simultaneously the large and medium cup sizes.All lights are still flashing.Even tried a new outlet. Keurig is out the door ,I am back to a reliable drip coffee maker
por
Adicionar a sua resposta
nicklomele será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 43
Últimos 30 dias: 227
Duração total: 20,626
