How do I install a new hard drive?
The casing appears smaller than the hard drive and case.
Esta é uma boa pergunta?
Here's how to install a 3.5" internal hard drive. Note that it takes a IDE/ATA drive, not an SATA drive. If installing more than one drive, the jumpers need to be set up as Master on one drive and Slave on the other to avoid a ID conflict.
Esta resposta foi útil?
Adding the link +
you bought the wrong size HD (possibly one for a laptop not a desktop) Height (mm) 26.1 Width (mm) 101.8 Length (mm) 147.0
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 1,577
