Ir para o conteúdo principal
Guias de reparo, desmontagem e informações de resolução de problemas para a versão atualizada da segunda geração do iPad da Apple com Wi-Fi, disponível com 16, 32 ou 64 GB de armazenamento. Lançado em março de 2012. Identificado pelo número de modelo A1395 e EMC 2560. Possui um chip de processador menor e uma construção interna atualizada. Os reparos exigem o uso de calor e alavancagem cuidadosa.
Looking for WiFi Antenna Part?
I note that iPad 2 Bluetooth/Wi-Fi Antenna says its not for the EMC 2560 model, but is there a suitable antenna available somewhere?
Imagem de Replace the Bluetooth Wi-Fi antenna compatible with the A1395 EMC 2415, A1396, and A1397 model 2nd generation iPad tablet.
Produto
$14.99
Esta é uma boa pergunta?
Pontuação 0
1 comentário
So what's the verdict, does this one work? The post labeled as the answer is indeed AN answer but hardly a solution and leaves the issue annoyingly unresolved and in an ambiguous way. I indeed have an iPad EMC 2560 that I'm about to replace the logic board in and was going to grab the cheap & especially fragile parts for the numerous reasons to do so and not that I won't be able to complete my repair without it but now I'm just curious what is so different or incompatible about the EMC 2560's and what's the solution or reccomendation if one should happen to require a replacement antenna for this model. Thanks in advance.
por
Adicionar um comentário
2 respostas
Solução escolhida
I think this is it: http://www.powerbookmedic.com/Wireless-3...
Esta resposta foi útil?
Pontuação 1
1 comentário:
Sorry but that one says its the 3G antenna not the Wi-Fi one ?
por
I've replaced hundreds of iPad 2 antennas and never worried about which model it was. The connection is the same on them all and the mounting is the same. There are no electronics to deal with, its all analog.
You should be good to go. I do remember seeing a couple iPad 2.5s with weird antennas. If you could post a pic of yours, I could tell you 100%
Pontuação 1
Adicionar a sua resposta
Wayne Lavis será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 22
Ao todo: 485
