Ir para o conteúdo principal
Display off center after replacing screen...
just replaced my iphone 6S screen and everything works for the most part but the display is off.. the bottom of the dock on the home screen has a thin black bar and so does the right of the home screen. im not sure if this is an actually technical issue or the replacement screen i purchased is flawed.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Can you upload a photo? Sounds like the screen was assembled poorly.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Flawed screen. The LCD was adhered to the glass off center
Esta resposta foi útil?
Pontuação 2
I have the same problem. Small band (about 1 mm) at the bottom of the screen. And the top of the screen looks slightly tilted. I also received a damaged battery. Terrible experience with Ifixit
Pontuação 0
Adicionar a sua resposta
alexhrnchk será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 1,322
