Ir para o conteúdo principal
Tablet de multimídia com tela de 7" da Barnes & Noble, lançado em novembro de 2011. Fácil de consertar, requer simples ferramentas de separação e chaves de parafuso.
I forgot my password
how can i reset my nook u ? i forgot my passcode
Esta é uma boa pergunta?
Pontuação 20
3 comentários
Where is the answer I need this help with mine
por
Power on and once you see read forever press and hold power button until it offers off. Repeat this 8 times and the nook will clear and reset to factory image them go into settings and factory reset
por
I tried this and it did not work---was on phone with support for 1 1/2 hours could not help me either---
por
Adicionar um comentário
2 respostas
Solução escolhida
kimberly, how can i reset my nook u , 3rd link gives clear instruction on how to do factory fall back, just make sure nook is plugged in when doing fall back. Check the attached links,instruction and guides, Good luck.
https://www.youtube.com/watch?v=4_Rw_kue...
https://print.nookpress.com/forgot_passw...
https://bookclubs.barnesandnoble.com/thr...
Esta resposta foi útil?
Pontuação 4
Hi Kimberly,
This website might be able to help you:
https://www.techwalla.com/articles/how-t...
Pontuação 1
Adicionar a sua resposta
kimberly será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 46
Ao todo: 34,721
