Ir para o conteúdo principal
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Perguntas Visualizar todos
Why can I not click by pressing down on my trackpad
I have a 13" macbook pro, first unibody model from 2008 (2 gb ram, 2.26 ghz, 160 gb).
I used to run it on snowleopard untill recently. i could not press down on the trackpad to click. after clicking about 10 times, the laptop registered only 1 click.
But the trackpad was fine otherwise, it could sense my gestures and taps just fine.
i had the touch-to-tap option turned off, but i had to turn it on to use the laptop.
As my laptop was under warranty, i took it to the service centre. the guy opened up the laptop and said the trackpad was fine, he asked me to erase the hdd and re install the OS.
I did and my laptop was fine again
That was 3 weeks ago. now my laptop cannot click when i press down on the trackpad again. i run leopard 10.5.8 now. please help.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
The 2.26 was 2009:
Apple MacBook Pro "Core 2 Duo" 2.26 13" (SD/FW) Specs
Identifiers: Mid-2009 13" - MB990LL/A - MacBookPro5,5 - A1278 - 2326*
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Introduction Date: June 8, 2009 Discontinued Date: April 13, 2010
Please give us the last three letters of your serial number. This machine may still be covered under warranty. Take it back and make sure there is a record of your returning it. I would take out AppleCare to extend my warranty. If it's doing the same thing with 10.5.8 as 10.6, try upgrading to 10.6 again.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Good answer +
por
I had the same problem with my trackpad. When I got it the physical click was a bit difficult to register (I had to click hard to have it register). Now a year and a half later it's just worse. I practically have to mash it down with an uncomfortable amount of force to make it register.
I would think if it makes the "click" sound it should be registering but this is not the case.
I read somewhere that you can adjust the sensitivity by a torx screw on the bottom of the trackpad. By opening the MBP and removing the battery I see a torx screw but I don't have a bit to fit it.
I do not believe this issue is a software issue. It happens in Leopard, Snow Leopard, Windows 7, and Ubuntu.
Pontuação 1
Adicionar a sua resposta
Tapas será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 2,148
