Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
Earpiece not working after screen replacement
Hi guys,
I have replaced the screen on my Dads iPhone 5s after the digitiser stopped working. However now the earpiece doesn't work. I thought that it might be the flex that is the problem however the front facing camera still works, what is the problem? I have tried reseating the earpiece but that hasn't worked.
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
There are a few reasons as to this why this may have happened, I'll start from the top being most probable to the bottom being least probable:
1. The front camera flex / ribbon cable assembly has a physical tear on the cable cutting the line to the earpiece speaker connection.
2. Alignment issue with the front camera ribbon cable and earpiece speaker.
3. The front camera FPC connector (the ribbon connector on the logic board) has bent pins.
4. The earpiece speaker has gone faulty somehow and needs to be replaced.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Jed Holmes será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 728
