Ir para o conteúdo principal
colored lines on screen?
My phone has colored lines on the screen and half the screen is frozen all because I dropped it. If I repair this at the repair phone place will it restart my phone?? Like would all my photos, contacts, notes, etc be on my phone after they repair this or will i need to set it up like a new phone again?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
No. Chances are, the screen is damaged and needs to be replaced. A simple, harmless repair. The only time you would lose all of your info, is if the Hard Drive was damaged.
Esta resposta foi útil?
Pontuação 1
2 comentários:
The data is stored on a NAND flash memory chip on the logic board, it's not a hard drive but it's a solid state drive basically.
por
I just say hard drive because its easier understand, and because SSD's and HDD's are both technically hard drives.
por
My iphone 6 screen display shows pink/ blue/ purple tint with vertical lines. And the recent opened apps appears in the background with low visibility when its on home screen. Please help!
Pontuação 0
Adicionar a sua resposta
Jay z será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Ao todo: 3,125
