Ir para o conteúdo principal
Why does TV power on then go dark
My Samsung UN50H6350AFXZA 50-Inch Class 1080P Led Smart Hdtv TV has two cracks in front screen, it powers up and says Samsung smart TV and then goes to a grey screen. I can still hear sounds.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
it's not cracked it don't show a picture when it comes on.
por
Adicionar um comentário
1 resposta
Samsungs always have issues. Try turning it on with an input active on the port it comes up on. If it powers up on TV then you will need an active video signal on the TV input. Or an active input on the PC input. Many Samsungs will turn off - if there is no signal being received on power up. If you cannot see if you can hurryly change the input to one you have a signal on. LIKE VCR or AUX. Anything will do to keep it from turning off.
Good Luck!
Esta resposta foi útil?
Pontuação 0
1 comentário:
I never thought of that and I bought the TV with no power cord or actually it was a trade that I have about 65$ in so I'm hoping it an easy and inexpensive fix. I have never had anything else hooked to it so now I'm going to have to drag it in from garage and try this. Thank you
por
Adicionar a sua resposta
Alan Cribbet será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 109
