Replacement fan for power supply
Hi
I need to replace the fan inside the power supply. I cant find any for sale on the net. Does anyone hav a prtnumber or link for that part
Esta é uma boa pergunta?
Hi
Rune, I had previously posted the wrong replacement fan, apparently OEM power supply fan hard to find, a lot of links say fan not available, plenty of complete power supplies though if you had too go that way. Check the link below, Kenny tells how he installed a replacement fan 10x10 fan from Mouser BFB0512HHA-C with good results. Hope this helps.
Esta resposta foi útil?
Thank you
I have red the article
Grease only works for a short time. I will try the other solution in the article, buy a Mouser BFB0512HHA-C.
Your answer was very helpful, thanks again for finding this link.
If you check my xb1 power brick disassembly guide I have a photo of mine which clearly shows the fan info. Just search xbox one power brick disassembly on ifixit. I hope this helps you find what you
Replacement found $10+ shipping. This was just a very quick search and only checked 2 posts on amazon. Maybe possible to find it cheaper elsewhere so you'll have to do some online browsing. Happy gaming!
Últimas 24 horas: 6
Últimos 7 dias: 11
Últimos 30 dias: 49
Duração total: 11,314
