Ir para o conteúdo principal
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
20 Perguntas Visualizar todos
Will not power up unless SMC reset is done
Apple MacBook Pro "Core i7" 2.3 15" Late 2013 (DG) Specs
Retina Late 2013 15" - ME294LL/A - MacBookPro11,3 - A1398 - 2745
I'm asking this because I had three abscessed teeth pulled yesterday, on pain medication and thinking is just not all that good today ;=() @danj
I know I know the answer but it's not coming to me.
I replaced a slightly water damaged keyboard on this machine about a year and a half ago. It has run well for the customer ever since. Running 10.11.6.
Was able to all updates.
When machine is shut down it will do nothing: when trying to power up from power button. Just dead, no sounds no lights.
Did an SMC reseat and it starts right up and runs perfectly.
I can't remember right now what this is. Hoping someone can jog my memory.
Esta é uma boa pergunta?
Pontuação 2
7 comentários
@danj fever is down but I'm still drawing a blank on this one. Thanks for the good advice on not ding anything when brain is only 1/2 there.
Hope meeting mom went OK, Things are starting to get serious when you start meeting moms ;-)
por
@mayer - Are you able to hit the power pads to start it up?
por
@danj forgot where they are
por
This is one of the fun ones ;-{ You'll need to short across one of the pins to ground. Here's the poop: Power pads
por
Thanks Dan, I better wait till my hands are steadier and I can count before attempting it.
por
Exibir mais 2 comentários
Adicionar um comentário
1 resposta
Solução escolhida
Fought with this one for three weeks. New battery.
Everything worked it just wouldn't start. Could not find anything.
I replaced the keyboard today. It all works now.
Just that one bad key.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
mayer será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,495
