Ir para o conteúdo principal
iPhone froze while recharging
I did the repair to replace the battery and the iPhone immediately thereafter worked fine. Made calls, answered calls. Sent and received emails. Browsed the web. Ran the phone down to less than 10% per the instructions. Then started to recharge using the iPhone charger.
After 13 hours, the phone bizarrely indicated that the charge level was either 0% or 60%. It was also frozen as it would not turn on and could not reset and could not be rebooted.
Any thoughts?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I think that it can be 2 problems.
1. The battery you put in it was a bad battery just try a second one
2. The U2 chip on your motherboard is damaged so you would need to replace that
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
simondavid será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 33
