Ir para o conteúdo principal
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Perguntas Visualizar todos
Are the iMac 2133 logic boards from 2007-2009 compatible?
I was recently given an iMac 20 2133 with (what I believe) is a bad logic board with a 2.4ghz processor. In searching for a replacement logic board, I saw that the 2007-2009 logic boards were very similar except for the processor and RAM speed. Do I have to stick with the same year logic board? If my logic board is 2007 2.4, could I use a 2008 2.66 or a 2009 logic board? Thank you in advance.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Sorry No, not interchangeable!
These are the possible logic boards for you're system as they are all within the same family series: iMac7,1
Esta resposta foi útil?
Pontuação 1
1 comentário:
Adicionar a sua resposta
ramverma será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 279
