Ir para o conteúdo principal
Released April, 2014. CPU - Quad-core 2.3 GHz Krait 400, GPU - Adreno 330. Display - IPS LCD, 16M colors, 1080 x 1920 pixels, 5.2 inches. Internal memory - 16 GB, 3 GB RAM. Android OS, v4.4.2 (KitKat). D6502, D6503, D6543
57 Perguntas Visualizar todos
My Xperia z2 screen, proximity sensor, gyro, rotation sensor, noise c
My Xperia z2 having following problem
Suggest me parts
1. Glow mode of screen not working
2. Gyro compass , proximity, rotation sensors not working
3. On display 1 horizontal pixel line not working
4. Noise cancellation not working on headphone, headphone is good
Problem having in mobile
Please suggest me parts to replace not whole mobile :P
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
I have the same problem about sensors and noise cancelation, what u did to fix them???
Esta resposta foi útil?
Pontuação 0
1 comentário:
I have the same problem about sensors and noise cancelation, what u did to fix them!? Also how to get the parts
por
You would need a new logic board which might not be to easy to get a hold of as a sparpart but if you buy a broken phone where the logic board is not damaged it might get cheaper that is waht I did. I would try this first to see if the problems with the display go away if you change the logic board. If they remain then you would have to buy a new display. They are sold at many places like e.g. e-bay.
Pontuação 0
Adicionar a sua resposta
ntpatils será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 9
Duração total: 824
