Ir para o conteúdo principal
Samsung's fitness-oriented smartwatch, featuring a curved super AMOLED touchscreen display. First released in April 2014.
20 Perguntas Visualizar todos
Why will my Samsung Gear Fit no longer charge?
I've had this for about 9 months now (had another, but lost it on a mountain), and it just stopped being able to charge. Tried switching cables, but that didn't help. Watch is now dead and still not charging
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Pergunta mais útil
Usually it’s corroded or dirty contacts. If they are only dirty, You can clean them with a small screwdriver or Q-Tip and some cleaning alcohol (Don’t drink! Just apply to contacts!)
Or you can change the contact-plates yourself. There is even a very good video on this on YT (https://youtu.be/vxvehGQG2YQ).
Esta resposta foi útil?
Pontuação 1
Replace the battery..
Pontuação 0
Check the backside of the watch. I have a similar problem except my issue involves the 2 visible copper charging contacts being corroded and rusting off from perspiration, and also showering with the watch on. My contacts will need to be replaced very soon in order for my watch to continue to charge. In your case...I would check to see if those contacts are damaged. If not, I think the earlier comment to change the battery would be a wise second step. Hope this helps. I'm just browsing right now to find a way to order those copper contacts. Good luck!
Pontuação 0
1 comentário:
Hi Trevor, I also have the same problem with my copper contacts. Have you found a solution? I dont find help on this issue. TiA. Good luck.
por
Adicionar a sua resposta
thechessmeister será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 15
Duração total: 2,307
