Ir para o conteúdo principal
This Power Mac G4 has Mirrored Drive Doors.
80 Perguntas Visualizar todos
No chime, black screen, fans all running?
I push the startup button on the computer, I hear a motor click or something, and then get no chime, no image, then after about 10 seconds all fans come on. The screen is an older 23" HD Cinema display. There is no paperclip hole in the optical drive to startup from OSX disk. I believe I lost the image when I reseated the Graphics card.
I've replaced:
(2) Hard Drives.
Battery
Logicboard
DP CPU
I've reseated or unplugged and plugged back in:
Computer speaker
RAM in all 4 slots
Graphics Card
Battery
I've reset the:
PRAM
Battery
Logic Board
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
3 respostas
Pergunta mais útil
This is about the eighth question on this same machine. Try starting up holding the mouse button down to eject the disk drive.
Esta resposta foi útil?
Pontuação 1
5 comentários:
Yes I know. It takes a while between ordering parts to try solution. I'm still considering upgrade, but want to get the computer working first. I have followed, pretty much everything suggested except starting up from OSX disk, which I can't do unless tray is open. Depressed mouse, pushed start up, tray did not open.
por
Took out optical drive, put OSX disk in tray, nothing. Hooked up firewire cable to Powerbook G4, not recognized as remote hard drive.
por
Good beginning +
por
I've never seen a full sized disk drive without an eject hole. What is the brand and model number?
por
I don't know the model, when I took optical drive cage out, there was an eject hole I could use, the way it was built with the hole pretty low on unit, the hole was covered by the frame of the (2) mirror doors. It is not the original optical drive, but has been working fine for several years.
por
boot with only one chip of ram and try using different ram.
Pontuação 1
2 comentários:
por
Took (3) RAM chips out, left (1) in, no change. Will locate a different RAM chip and see if that works.Will have to order, so will take a few days. Mr. Mayer also suggested this previously.
por
Lots of discussion with this issue but no one ever say, "i have a fix".
Has anyone ever solved this problem?
Pontuação 0
Adicionar a sua resposta
R Michael Olexo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 15
Duração total: 2,911
