Ir para o conteúdo principal
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
20 Perguntas Visualizar todos
Do the replacement screen have one or two connecting ribbons?
iMac 27" EMC 2546 A1419 (Late 2012)
Hello, Do these replacement screen
> 27-inch LCD LM270WQ1-SDF1 PN: 661-7169 <
come with one or two connecting ribbons?
Seem that there should be two to disconnect when on takes the screen apart but when I go to order a replacement screen, seem that they come with only one ribbon.
Shouldn't there be one for the LCD and one for the Digitizer?
For this iMac
iMac Intel 27" EMC 2546
Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
OK. FYI: When you buy the Screen assembly, it only comes with one connector cable, the one shown in this correct model screen assembly on the picture Jamie uploaded. The Ribbon cable to the new Screen Display port lcd cable, 98% of the time does not come with the new Screen you order and must be purchased separately only IF, your existing one is damaged. Ask the seller if they send it with the replacement screen so you are aware if to order one!
One more detail! You will need new mounting adhesive tape to reassemble your new Screen! You must buy a new set or ask the seller if they send an adhesive kit with the screen they are selling you!
This will save you time after your get the screen, so you don't have to wait again for just the Adhesive to arrive, to complete your installation!
If the existing Display port lcd cable on your existing screen is OK, you can just swap the old screen Display port lcd cable to the new Screen Assembly!
See This interchangeable ribbon Display port lcd cable here below!
The 2nd connector, the Display Ribbon!
Hope this saves reader's time/delays, money and troubles!
Esta resposta foi útil?
Pontuação 0
OK, thanks, that is what I have been seeing.
I suppose one has to take the Display Port Cable from the old Screen and swap it to the new one!
I was afraid in ordering because there are two ribbons to be disconnected but I guess this port ribbon is disconnected at both ends and is swap-able!
Thank you Jamie, that was a quick response!
Cheers
Pontuação 0
1 comentário:
Quick but incorrect!
por
Esta resposta foi dada inicialmente para uma outra pergunta.
There is just one ribbon as you can see in this full assembly unit below
Good luck with your repair!
Pontuação -1
3 comentários:
It is alway good to post links to your references. We have no way of knowing where that one came from, or if it is even the correct display.
por
Look carefully!
The image of the display unit you have in your answer has two connections. The black cable on the left is the backlight power lines not a ribbon cable. The ribbon cable is missing in this image, it connects to the top midpoint connector.
por
Thansk Dan for the Clarification!
i got it!
The Ribbon cable is the one that comes off both ends from the old screen and placed in the new screen!
Do I have this right now? About the reuse of the Ribbon cable one!
por
Adicionar a sua resposta
Carlos será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 412
