Ir para o conteúdo principal
The BLU Vivo XL was released in January 2016 as part of BLU's budget line of smartphones.
Can't change default storage from SD to Phone?
I have a BLU vivo XL, and I have a micro SD card into it to expand my storage, but it has been downloading everything onto that SD card and now its full, I still have space on my phone but it won't install anything to the phone, only the SD card...Please Help. I have taken the SD card out and then installed stuff and it worked. But I can't change the default storage.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
5 respostas
Solução escolhida
Hi,
Check the following setting:
Menu > Settings > Device > Storage and see what the 'default' write disk is.
Esta resposta foi útil?
Pontuação 3
I have a special key for my Blu Vivo xl 2 and it opens the sim as well as the micro sd card slots it should com in your case. Also I a good way to transfer the partial information to your new phone is essential to not losing too much room as a confused waste in your phone's storage. Download an app if need be in the google play store.
Pontuação 1
Can you tell me how to open the XL2 to insert an SD card? I can't find an answer to this anywhere.
Pontuação 0
Thanks! :-) Much appreciated. Do you have a specific app you recommend?
Pontuação 0
How can I transfer files from Phone to SD Card with my VIVO V7 mobile? Do I need to use PC? How about changing the default storage? It's so complicated.
Pontuação 0
Adicionar a sua resposta
Levi Warkentin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 8,702
