Ir para o conteúdo principal
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
screen flckering after replacement
I replaced the screen/digitizer on my daughter's Ipad mini. it powers on and seems to function with the touches etc but the screen flickers and looks horrid. It gets brighter and then dimmer every 5-10 seconds and you can see the previous screen faintly behind the current image, especially when the light gets dimmer. There are also horizontal and vertical lines distorting the image. I didn't glue down the cover yet and am wondering if maybe the LCD connector isn't seated properly. I am definitely not an expert (I replaced my friend's Ipad 3 screen quite easily) but this was so much harder! Any thoughts would be greatly appreciated.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hello! It sounds like 1 of 2 things based upon the limited information I have. Either the LCD screen is defective or it was not installed properly. You can buy another screen and test that theory or double check your installation. Without seeing the device it is hard to determine.
Esta resposta foi útil?
Pontuação 0
1 comentário:
SPAM - half your answers promote this Drive Savers Repair Shop.
por
Adicionar a sua resposta
karen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 81
