Ir para o conteúdo principal
Screen wont work after replacement
I just had my screen replaced today at the mall and it worked great for an hour then when i got home it worked great for another hour then the screen went black. the phone still played my ringtone when called and vibrated when charged, but the screen wont turn on. i tried the reset thing with the power and home butten. the screen flashes for a second then turns off any help? i went back to the repair guy and he tried another screen and it did the same thing any help?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
the repair shop should give you a new phone. You didn't sign a waiver saying that your phone could be damaged (i hope you didn't). If you didn't, they legally have to make it right since they damaged your property.
Esta resposta foi útil?
Pontuação 0
Hi,
Add you put the screews on the right place? That usually happens when the screen is replaced because some people change the screews and damage the streets under it.
Sorry about my English.
Pontuação 0
Adicionar a sua resposta
lowell wood será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 14
Ao todo: 243
