Ir para o conteúdo principal
Repair guides and support for LED, LCD, HD and other Vizio TVs.
Issues with Vizio Remote
I bought my 3D Vizio in 2012. I dropped the remote last month and it stopped working. I have since purchased two remotes - the same one that was damaged - and neither of them will work. Fresh batteries, but neither will operate the TV. Am I doing something wrong? Does it need to be coded in? I've also tried two different universal remotes, and had no luck with them either!
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Solução escolhida
Dustin, your remotes do have to be programmed to sinc. with TV. The manual that came with remotes should have explained this/procedure. In case you have no manual, I will post links to instructions on how to program remotes. Dustin you can also do a google search your remotes make and model# manual.
VIZIO programming codes, 1169 1168 0081 0112 0143 1011
0050 1000 1222 1322 1189 0218
0219 0220 0221 0222
Check the attached links,instruction and guides, Good luck
I hope this helped you out, if so let me know by pressing the helpful button
http://cdn.vizio.com/documents/downloads...
http://vizhdtv.com/vizio-tv-remote-codes...
http://www.brighthub.com/electronics/hom...
Esta resposta foi útil?
Pontuação 1
The remote I have now, and the remote that came with the TV are the same type... they don't have a "TV" button or a "Set" button, so I have no idea how to use those instructions. Here is the remote I have - http://oi65.tinypic.com/33bo0n4.jpg
Pontuação 0
Adicionar a sua resposta
Dustin Grubbs será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 12
Ao todo: 3,836
