Ir para o conteúdo principal
What is causing barely seen vertical line
I have a thunderbolt display that recently showing a barely seen vertical line (see picture) some kind of noise, there is nothing else wrong, neither color or picture.
I was wondering if its noise from power supply or logic board or T-CON board, the lcd is LM270WQ1-SDB3.
I dont have a schematics and can not find it either by googling (checking probe point with oscilloscope ).
link to picture:
https://s9.postimg.org/6aczv1z2n/DSC_000...
thanks in advance.
Ted :)
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
The ribbon wire inside of the monitor may need to be "reseated". Basically unplugged and plugged back in. Before you go through all that trouble try to eliminate ALL electro-magnetic sources of interference. If it persists, it may be the ribbon wire.
Esta resposta foi útil?
Pontuação 2
2 comentários:
How about a link to how to do that?
por
http://google.com <-- try this one, John. :)
por
Adicionar a sua resposta
ted lindsay será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 555
