Ir para o conteúdo principal
Um "laplet" transformável da linha Lenovo Yoga.
Why does my screen have small flickers?
Hi guys. I recently got a lenovo yoga 14 and ever since the set up, my screen has these small, box shaped flickers. I installed the nvidia drivers and sort of mitigated the settings, but that had almost no effect. They pop up every once in a while, and I am concerned. Can I fix this? Thanks. Ps, the screen only flickers a little, it does not shut off.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
It might be your connection check your cords are plug in right, or you just might need to clean the connectors . You also can go on to youtube.com to watch videos and see if they can fix your problems. I hope this helps.
Esta resposta foi útil?
Pontuação 0
1 comentário:
thanks, ill try looking on youtube and cleaning my connectors. I hope it works
por
It sounds almost as the problem I had. When I typed an address in Firefox and the suggestions were showing, they kind of got blurred out by black boxes.
I tried installing the intel graphics drivers from intel, but they did not recognize the hardware.
So I installed the intel vga drivers from lenovos site and after that the problem was gone.
This was for the yoga 510-14 isk, but it might help.
Cheers!
Pontuação 0
Adicionar a sua resposta
Droneking246 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 18
Ao todo: 933
