Consistent dripping sound coming from tank
There is a consistent dripping sound coming from the tank of my toilet. What could it be?
Esta é uma boa pergunta?
Over time the flapper - which is soft and supple new - becomes dry and hard. Replacing the flapper will normally fix a dripping issue, and it's about a 5 buck repair.
Esta resposta foi útil?
Flap which stops water to come in side has been wastage.It would be change.
Really a score of 8 on this answer! Really amazing and total BS. Having your buddies vote a poor answer up like this risks getting you banned from the site.
Here's the guide on replacing the flapper: Toilet Flapper Replacement
Try putting a new tank kit in it?
It may be time to replace the whole kit soon anyway. As there is no visible water leaking from the tank and no overflows ever, I just wonder what it might be.
It' cause of a bad flapper, it can't hold the in the tank and the water is dripping from the tank. You should replace the toilet flapper asap.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Ao todo: 17,786
