Ir para o conteúdo principal
wifi problem after lcd and back cover replacement
hello, i'm Dan, i have a problem with my z3 compact's wifi. I replaced the lcd and the back cover, and the wifi don't work good... The signal at 2,4GHz is so bad and at 0 mb in download, with the 5GHz is a bit better but not enought. I don't know where is the wifi antenna, and if i could touched it or broked it when i moved the motherboard or others.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
Check connetor on mainboard and plastic main frame. Wi-Fi antena is in a frame. Check screws and spring connector on mainboard (it goes to frame). Maybe you can broke it or distort it.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
dan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 942
