Ir para o conteúdo principal
O iPhone 5C da Apple foi lançado em 10 de Setembro de 2013. O reparo deste smartphone é similar aos modelos anteriores. Você precisará de chaves de Fenda/Philips/Torx 0.8 e espátulas de plástico. Disponível nas versões GSM ou CDMA / 8, 16, 32 GB / Branco, Rosa, Amarelo, Azul e Verde.
1233 Perguntas Visualizar todos
The phone is not charging even though it shows the lightning bolt.
I have an iPhone 5c here in my shop.
It indicates the phone is charging but does not seem to ACTUALLY be charging.
I tested out a new battery and it was the same problem.
Swapped out the piece that has the Lightning port, headphones, speaker etc and inserted a new one. Same issue.
I looked online on this issue and saw a lot of iPhone 5s issues regarding a burned fuse but the fuse is of course, not on the 5c mobo.
Has anyone else experienced this and if so, were you able to fix it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Check the battery connector. Make sure its solid and not coming up from the board. Make sure there are no bent or missing pins. If that all looks good, Google the schematics for the 5S. Chances are that one of the charging components popped.
Esta resposta foi útil?
Pontuação 1
1 comentário:
checked them out, nothing is bent, all pins are there, and I tested it with a new battery and the original one, both in excellent condition. This is a 5c though, havent been able to find a schematic for that yet.
por
Adicionar a sua resposta
shinseraph22 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 1,077
