Ir para o conteúdo principal
Also known as NX.MH1AA.011. This 15.6" LED touch screen laptop was released in June 2014.
6 Perguntas Visualizar todos
Laptop Key (W) is not working properly
Hello.
I'm using Acer Aspire E1-510 laptop and my "W" key started "blocking and freezing" 2 days ago. I don't know why is that happeing but i thought it was because of the dust,so i vacuumed and it didnt help. I also removed the key and tried a "deep" dust clean,but it didn't work...
Sometimes it works normally but sometimes i have to push it about 20 times to write a single "W".
Sorry for my bad English :)
Cheers!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Usually this is because of debris or dust on the connector for the keyboard. My laptop had this problem.
I took the laptop apart until I could get to the keyboard connector. I removed the keyboard and cleaned the connector by taking an eraser and "erasing" all the dust off. The pins were a lot more shiny and the keyboard worked perfectly after that. I hope this helps.
It could also be helpful if you searched "Acer Aspire E1-510 keyboard replacement" so you can see how to properly remove it.
-Jono
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Dino Covic será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 525
