Ir para o conteúdo principal
Is there internal microphone in the Apple TV 2nd Generation?
Does Apple TV 2nd Generation support the view-chat?
If supported the image chat, is it through the internal microphone part or furnished with a Web-camera like TV that Panasonic makes?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
There is definitively no microphone in ATV- no reason to justify the addition of an analog audio Codec in this box. If it were the case, there would also be an analog output (likely on a 3.5mm stereo jack).
If video-chat was to be added, I would imagine that it would be through an accessory that would provide both video and audio capture, better located than ATV that may be hidden in a cabinet...
This said, most webcams use the full USB power, or 500mA/5V, which is half the total power available... Not sure there is enough overhead for this...
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
coco será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 3,437
