Ir para o conteúdo principal
Unresponsive screen with white bars at the top?
So about a month or two ago, my friend stepped on my phone on accident and cracked it and bent it a bit. At first, the only problem was the cracks, but about a week or two ago, I noticed a white bar are the top of my phone screen glitching and when it does it, my screen is unresponsive. I've tried messing with it to try and forgive out what is wrong, and I think it has to do with it being bent, any advice or fix?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Either the screen is damaged or there is miniature fractures starting to develop on the logic board, and this may effect the touch ic, I would try changing the screen first and see if that resolves your issues, and try get a new housing, to minimise anymore chance of fracturing on the logic board. :-)
Esta resposta foi útil?
Pontuação 1
its a common problem in iphone 6 plus. your touch ic is causing that problem. see this video from ipad rehab and try if you can fix it
https://www.youtube.com/watch?v=To6dJYgd...
Pontuação 1
Adicionar a sua resposta
Nelson rivera será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 6,041
