Ir para o conteúdo principal
Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Perguntas Visualizar todos
Headphone Jack/Speakers not working
Hi guys, I recently bought a Macbook Pro late 2011 from eBay, and it sure has seen better days. There is no sound at all and resetting the Nvram and SMC did not fix it. The headphone jack also does not output any sound. When I check the sound preferences, there is no output and input detected. The only way I can get sound output is through bluetooth. Also one of the usb ports is not working.
The seller claimed to have no water damage, and upon further investigation on the logic board, there really isn't any corrosion.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
The headphone jack has a switch inside which directs the output to either the headphones or internal speakers often it gets damaged. The other possibility is the Codex chip is blown. In this case I'm suspecting the later here as you state the Sound preferences Output tab is not showing the Internal speakers or the Input is not showing the Internal Microphone and/or the Line In, double check if that is correct.
As for the USB port I would try a powered USB hub which then you connect something to test it to see if the power services are gone Vs the USB driver logic. If the device responds on the dead port then you have a simple fix a blown fuse link.
Both are repairable, but, you'll do need to have micro soldering skills and the proper tools and access to the needed parts.
I would recommend you locate someone with these skills to service your system or replace the logic board your self.
Esta resposta foi útil?
Pontuação 3
2 comentários:
Okay, I tried the usb hub and the little led lights up but when I connect my iPhone to it, no data is transferred to it, or even power. But when I do the same on the other usb port, it works. As for the sound, I think I may be sol, and might just upgrade to an early 2012 logic board for usb 3.0.
por
Are you sure the USB hub was powered? That is it was plugged into its own AC to DC transformer.
If not that's what I would expect as a reaction as that doesn't change things. If it was powered then you have a bigger board level problem so then it would make sense to replace the logic board.
por
Is there a way to fix the sound if the switch in the audio jack is damaged?
Pontuação 0
1 comentário:
@sagun - How about creating a fresh question with all of your details so we don't get things confused here.
por
Adicionar a sua resposta
Kyle C será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 2,566
