Ir para o conteúdo principal
TouchID and Home Button not working after replacement
Hi,
I order from a seller on eBay a iPad Mini 4 LCD/Touch replacement. I saw that it has to desolder and solder again a flex that connects the home button to the assembly.
After the replacement and transfer for this flex the home button will not work, but if I solder it again to the broken one. It will work flawless. any one had encountered this issue?
I test the same procedure on 3 different replacement LCD/Touch assembly and in neither will work, only on the original broken one.
Any help will be thanked!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
The home flex cable may be torn??
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Robert G será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Ao todo: 833
