Ir para o conteúdo principal
Android's 4.4 OS with a 1600 x 2560 pixel resolution.
45 Perguntas Visualizar todos
How to fix it without loosing photos
The display screen of my Samsung galaxy tab S 8.4 got broken and damaged after I got slipped on the stair case. Will I be able to repair it without loosing my photos and document S.it's totally damage d inside
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
As long as you did not damage the motherboard you can change the screen without doing anything to your data . You can change screens without affecting anything on your tablet ....but with that said its always best to back it up in case something unforeseen happens. Hope this helps
Esta resposta foi útil?
Pontuação 2
Try plugging it into the computer to pull the photos. If the computer will not recognize it then we can look into other resolutions.
Pontuação 1
Adicionar a sua resposta
Nipuni Poornima será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 86
