Ir para o conteúdo principal
Water damage - No Display - Components missing
Hi Guys,
I've been tasked with repairing this Water Damaged Xperia Z3 Compact which has lost its display. There is visible Damage/Corrosion to the LCD connector which I've cleaned of, but on closer inspection there are a couple components missing just beside the connector. I was hoping that one of you tech geniuses would be able to identify the missing components and give me a fighting chance of resurrecting this phone..
Zoomed In..
Many Thanks In advance
Paul
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Great pics, I unfortunately can't help on this once, but google up schematics and you may be able to figure it out from there.
por
@ifixphonesuk Sony only offer board swap for phones in warranty, They do not repair boards therefore schematics are no longer produced. You 'll need a working board to determine what component this is.
por
Adicionar um comentário
1 resposta
very low % repair, good luck if it's a hobby however commercially it might not be viable.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Paul Tulip será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 1,005
