Ir para o conteúdo principal
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
iMac second hard drive gets ejected
Having an issue after i install 2 different SSDs on one of my mid 2011 iMac using the 2nd ssd kit (sata cable and special power cable from the motherboard). Disk not Ejected Properly I'm trying to figure it out no luck yet!
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Adicionar um comentário
2 respostas
Solução escolhida
You'll need a fixed SATA II (3.0 Gb/s) HD or SSD for your system. If you review the Red note at the bottom of this: OWC Data Doubler. A SATA III (6.0 Gb/s) HD or SSD won't work in this system reliably. The systems SATA port has a known compatibility issue. You also can't use an auto SATA port sensing drive (one that can run in either SATA II or SATA III system) it must be a fixed SATA II drive.
Esta resposta foi útil?
Pontuação 2
Pergunta mais útil
The BUS on the optical drive port is not fast enough to handle it. Try putting a standard HD in that position.
Pontuação 2
Adicionar a sua resposta
lucastech será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 136
