Ir para o conteúdo principal
2.4 GHz Intel Core i3 with 4 GB RAM and 1 TB hard drive, shipped with Windows 8.1 as standard
How to reset bios
How to reset bios password
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta mais útil
in laptop the password bios is stored in IC like eeeprom you cant clear it by removing the cmos battery
in your model c50
you will have in motherboard 2 IC with name Winbond 32 and 16
you must pull out the winbond 32 (8pins) with hot air then put it in a programmer
then you must search for bios file with extension bin or rom and programme it into the IC
this is the only way to remove bios password
you need a tech
Esta resposta foi útil?
Pontuação 1
removing the mother board battery should help. check youtube for your model
Pontuação 0
Adicionar a sua resposta
ahmed331199 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 3,433
