Ir para o conteúdo principal
Guias para o tablet Sony Vaio Tap 11. Anunciado em 4 de setembro de 2013 e lançado em 18 de outubro de 2013. Número do modelo SVT112A2WL. O primo fino, elegante e atraente do Surface Pro 2.
Is it possible to upgrade the processor (e.g. 3560Y)?
I've got the Vaio Tap 11 with a 3560Y inter processor. Wonder if I could upgrade my system by replacing the processor with a better one.
  • Would this be possible?
  • Is the motherboard compatible?
  • What are (some of) the options for processors?
  • What's the way of working?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Marty,
You only option to upgrade the processor is by replacing the motherboard with a compatible one.
I am not sure that it will justify the investment.
I will recommend you to access the motherboard and find the exact model. Then check in Ebay for compatible replacement (including a different processor).
I could not find any documentation from Sony sharing technicalities to make our job better (as technicians).
You could try reaching team to see the official version.....in my opinion they will say that there is no way to upgrade.
Good luck and good repair.
JM - Montreal
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Martijn será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 23
Ao todo: 689
