Ir para o conteúdo principal
A Acer entrou no mundo dos laptops em 1997, quando comprou a divisão de PCs móveis da Texas Instruments.
1682 Perguntas Visualizar todos
acer laptop won't connect to wi-fi
i don't know why my acer laptop wireless is not working
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
4 respostas
Pergunta mais útil
i think update the wireless driver and reset the settings of wireless
Esta resposta foi útil?
Pontuação 4
2 comentários:
thanks worked for me
por
How to update if Wi-Fi not connecting,neither Bluetooth tathering,usb tathering.showing IP address failure.
por
check your device manager.
make sure the device is connected.
try updating the drivers.
Pontuação 1
i had the same issue i tried everything like reset or update the driver and many more than but nothing just seems to be working with issue . i thought it was the windows and reset the whole computer back to the new settings but still got no success and still having the same issue . now i think i should throw this computer i have no idea what should i do
Pontuação 1
5 comentários:
Hi, What is the model number of your laptop? What OS is installed? Has the WiFi ever worked in your laptop? Have you checked in BIOS to see if there is a WLAN enable/disable option?
por
i have the same question too . please help
por
Hi @ecclescolin,
Provide the answers to my comment above and we'll go from there.
por
OS is windows 10 and i am not sure about computer model
por
Hi @roberthickman,
On Acer laptops and PCs the model number is written above the serial number on a white label on the the bottom of the laptop or case. if there is none there it is also located in the BIOS area. Press F2 when you first start your laptop/PC to enter BIOS.
por
hi
1-maybe there is problem in WiFi card
2-maybe WiFi driver
3- maybe it isn’t turn on
Pontuação 0
Adicionar a sua resposta
Robert Turner será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 3,211
